Interface your system......
Peter,Peter,Most of the navigation softwares will allow upload of route waypoints from the computer nav station to the Garmin 128. Some will allow download as well. With the use of digital charts and a nav software such as The Capn. Voyager you will have the ability to use the computer nav station as a full real time plotting system.The interface from GPS to computer is relatively simple as an interface cable will come with the software. This cable has a serial port connection on one end, which connects to the computer, and three bare wires for connecting to the GPS and/or autopilot.There are electronic components available to ease the install between the Computer, GPS, Autopilot and other NMEA devices such as depth sounder, as well as add a level of protection from voltage spikes. This protection is called opto-isolation and is well worth the money. See the tips for info on this. To interface to the autopilot, a switch is neccessary to control which set of NMEA data the autopilot is receiving. The switch set in the computer position allows output data from the computer to relay to the autopilot. This allows the route information to download from the computer nav software to the autopilot.The switch placed in GPS position allows the route information to download from the GPS and not from the computer.Most autopilots will accept only one set of NMEA data for use at a time. The switch allows the control of which set of data to send to the autopilot.Your computer will corrode do to salt air. Use a Computer Stowage kit to reduce the chances of circuit board damage. Also it will probably be neccessary to upgrade the RAM on your laptop to at least 64MB. My motto is "RAM is like money, You can never have enough".I run a P133 and it is slow using some of the newer, resource intensive nav software. Amos
