Maine: A couple of years ago, I had the Promariner battery charger go up and replaced it with a new one. I noticed some battery life issue (didn’t seem to last as long at anchor between charges) and purchased a Victron monitor (3/2012) from you (Thanks!). Last fall my FWD 4D heated up (very hot), so I replaced all the batteries with new East Penn AGM’s. Since then, I have never received the amp hrs in the house bank that I thought I should have, and the SOC has never matched up with the voltage since Victron installation. Last week, I took the batteries back to East Penn to be tested and was told they were good (except one was overcharged and one needed charge-they should have been the same voltage??). This weekend found a blown 300 amp fuse on the positive side of my FWD battery. Must have been blown for a long while. This allowed the forward battery to be overcharged (don’t know how?) through the negative and the AFT battery was not getting up to full charge and was doing all the discharging while we were at anchorage. I moved the AFT fuse forward and temporarily bypassed the AFT fuse and all is well. SOC is correct, Amp Hrs are better, and both batteries are the same voltage.
My question is: Once I replace the JJN-300 fuse, how do I know if one blows again before the battery gets overcharged? Is there a better way to wire the batteries, so I can’t overcharge a battery if a fuse blows? Would some kind of blown fuse indicator work (if so, what do you recommend)? FYI.. 2/0 awg battery cables are approx. 12-15’ and the battery charger is on all week, while the boat is in the slip. I have attached the schematic for the charging system. The only change is the negatives from the battery go to the Victron shunt and then to the Neg Bus. Thanks in advance!!
