G
Guest
For the 3rd time in 1.5 years my refrigerator has stopped working for no apparent reason. I went through the trouble shooting portion of the owners manual and checked the fuses, and for the 3rd time the fuse was bad. I changed the fuse at the unit, turned the power back on at the panel. Immediately there was a snap sound and the refer did not start. I checked the fuse again and it was bad.(hence the snap sound) I repeated the process with the same results.I am using a 15 amp fuse as per the manual. As I said.....this is the 3rd time that the same thing has happened. I have had the Adler/Barbour repairman down twice before for the same problem, only to be told that it is the curcuit module (about $300 each ) I am having trouble believing that this modual doesn't have a longer life span. I believe my problem is something other than the module My thanks to anyone who can help me with this problem.
