It's been mentioned that instead of using antifreeze in the water lines they can be blown out with compressed air. I would like to try it this winter but am not sure of the process. Is a lot of air pressure needed? Does the air line have to be connected past the water pump, or is it okay to run the air through the pump? Is a special adapter needed? Any advice is appreciated.Thanks,Manny
