G
Gary Wyngarden
Shibumi's Yanmar 3gm30f has about 1800 hours on it. Lately it's been getting harder to start when cold and is blowing white smoke out the exhaust on startup and leaving a small fuel or oil slick on the water near the exhaust.I had a consult on board on Friday with my diesel mechanic. He discovered high crankcase pressure which would cause oil to be forced out around the oil fill cap when loosened even a little bit with the engine running and significant pressure (estimated at 9 psi) out the crankcase breather.My mechanic believes this is caused by improperly seated or worn piston rings that are allowing exhaust gases to blow by into the crankcase. Nigel Calder's book would support that conclusion.At this point I can live with the reluctance to start and the engine is still running fine otherwise. My options appear to be three:1. Live with it for now. This would be ok, but we sail some places that can get dicey on occasions and I don't want to feel compromised by a questionable engine.2. Pull the engine and go through a spendy piston and piston ring, etc. replacement3. Since I would be pulling the engine anyway and am committed to Shibumi for the long term, go ahead and replace the engine.I'm really not pleased this is happening so early in the engine's life. I've owned the boat for four years and have put maybe a third of the engine hours on it. It's had plenty of TLC. Not sure about it's early treatment, but up to now have had no problems with the engine.Any advice from the voices of experience will be appreciated.Gary WyngardenS/V Shibumi H335
