Blocked through Hull fittings
Sep 11, 2019
168
Hunter 386 Lake St. Clair
Guys, my fresh water overflow and I believe my Sump Pumps through hull fittings are blocked. I suspect spider webs etc. Anyone have a good way of clearing the lines?
Sep 11, 2019
168
First time I've ever heard of them. Any tools/utensils that I could insert and clear out?
Oct 24, 2010
2,405
Hunter 30 Everett, WA
One time I was successful when our raw water inlet was blocked. I disconnected the hose from (in my case the strainer)
and held a cut off piece of hose tight against it and turned on the water. It worked great. The reversed flow did the trick.
Ken
  • Helpful
Blow them out..:plus: For Ken.
Water, Reverse flow of vacuum cleaner, or air form a compressor. I here even your boat horn can be used to blow air into a pipe and blow any stuff out. (Never tried it, but in a pinch one gets resourceful.)
