Russ Hauser
My new old C-22 bottom has lots and lots of blisters. This problem must be addressed before the boat goes back in the water again. Some of the blisters are open but most are just small raised bumps. When I sand over the blistered areas, lots of the blisters will be leveled off and faired into the hull. Will these blisters be okay if covered over with a couple of barrier coats and VC-17? Any open blisters will be cleaned out with a Dremel and filled then faired.
