N
Neil
I just bought an F235. It has been in the water about 3 yrs and has about 7 large (~1.5x3") oblong-shaped blisters under the waterline, which I will repair before putting it back in the water. Please tell me if my repair plan is missing anything, or just plain wrong:Wearing a good dust mask, goggles, and coveralls ...1. Grind blisters flush with hull, and then proceed carefully into the hull to remove remaining 'wet' glass.I plan to use a wire brush grinder on my electric hand drill - OK??? will it be easy to tell how much glass to remove? Are there any helpful tricks here?2. I'll blow out the dust and let the cavities dry out a day or so.?? can I squirt some acetone in the cavities to help drive out the water and hasten the drying?3. As the blisters are large-ish, I plan to fill the cavities with West System 405 epoxy, mixed with some West filler (to make fairing easier) and some chopped strand mat to add back some structural strength.?? I have some experience with this epoxy, and with woven fiberglass mat, but not with chopped strand mat - are there any tricks working with this pesky-looking stuff?4. (This is where it gets particularly hazy for me) ... I guess I should fair the repair spots flush with the hull, and then sand the entire hull to remove the old antifouling (it's currently the blue chalky kind that rubs off when you wipe it with your hand). Then I plan to paint a coat (more than one coat?) of some sort of barrier paint over the entire underwater surface, sand lightly (??), then put one (or more??) coat(s) of antifouling on.?? I may as well repaint the keel while I'm at it (I'll follow the great advice on the rusty keel repair someone posted recently) - but I'd like some advice about the various coatings I should/could use. I plan to use the boat mostly for club racing so I'd like a nice smooth bottom - I gather there are two maiin types of bottom paint but I can't remember the main differences or the pros and cons of each.Finally, the topsides seem dull. I gather one can 'wax' the topsides to shine them up - what are some recommended products?I live in an inland area where the local marine shop only knows about power boats and the only commercial haulout yard doesn't do sailboat repairs (they bent someone's keel a few years back and got scared off sailboat repairs after that), so it's hard to get advice locally. Any helf anyone can give will be much appreciated.Thanks,Neil
