THE GREAT LEARNING CURVE!!
Osmosisinfo.com had the deepest explanation of the gelcaot/water problem I have seen, although there is some "off the wall" stuff about leaving bllisters open if there is no time to wash them out and dry them.'They basically said that if the resin ahd been heat cured there never would be a problem, but uncured resin, "wick effect of "fibers etc are all contributing factors.The stuff on Sailnet.com was more readable and reiterated some fo the same facts. Interestingly blisters per se are not the problem its the soggy/cloudiness of the underlying fiberglass resin as it gets water penetrated. Older hulls did not get blisters but could still get water-damaged.All of this is, of course, the worst case scenariao, Blisters between gelcoat and fiberglass lay up only are more trivial but the resin underneath should look clear (the big guys who charge $500 per foot for redoing laminates make an inspection window with a grinder to measure depth of water penetration.One thing I learned is that all blisters should be well washed out with fresh water before drying and fixing.Otherwise the trapped acids cause a return of the problem.Of course, living in the world of reality with $25 to $45 per day lay day charges real drying is almost impossible wihtout special measures.Blisters in in paint (even barrier coat) are also likely. I even remember painting a car with acrylic lacquer, wet sanding it proior to top-coating and it then rained almost daily for 2 months. It got little osmotic blisters with water in them!.I'll try to summarize all this and more in FIberglass Trilogy III coming out in May 2001.Jim W
