Did it yesterday
MitchJust did the bleading thing yesterday and you most likely not have to blead after the injector pump. In order to speed the process and not get tired manually operation the lift pump so I install a good quality pump ball in the fuel line prior to both filters. My way is to pump the ball and blead the secondary filter then do the same to the filter on the engine using the larger blead screw. After that loosen the blead screw on the fuel line just as it enters the injector pump and insuring that all the air is out of the line to that point the engine should start. Just in case, close the engine water input port and open it asap when the engine starts. If the engine stalls it probably means that some where in the line usually prior to the injection pump you have an air pocket, so just repeat the process. Oh yes, don't forget to close the fuel shutoff valve prior to changing the hose.
