John Horton
I recently purchased a 1986 Hunter 34 with the Yanmar 3GM30F engine and need to bleed the fuel system. I can bleed the air from the fuel filter and the fuel return line but I cannot bleed the air from the fuel injection pipe because I can’t loosen the nipple on the fuel injection valve side. This nipple has been rounded off by the previous owner making the 17mm wrench ineffective. I have tried using vice grips but still cannot break the bolt. In the area, there is very little working space and I am also limited to using an open-end type tool since the fuel injection pipe line is a part of the nipple that I am working with. Any suggestions will be appreciated. On another note, once I get the nipple loosened, it will need to be replaced. Is this nipple a separate fitting or is the nipple and the fuel injection line considered a single replacement part?
