Sanders LaMont
The engine (Yanmar 30 (actually 27 hp) )is running again.I spent an interesting evening this week scrubbing my fuel and then bleeding the engine to get it going again. A few questions:- When I tried (per the book) to prime the mechanical fuel pump by pumping the small lever up and down repeatedly, nothing happened. After quite a while, my experienced friend suggested pouring fuel directly into the pump through the bleed hole (we took the screw out) and that worked to prime the pump and get the air out.The question regards whether that reflected a common problem with the small lever/pump action, or a reflection of an inefficient approach?- That also led to two suggestions for a fix, which I would like your thoughts/experience regarding. First, I could install a new Racor with a pump attached (mine does not have one) and relocate it to the front of the engine compartment. Or, second, I could install a squeeze bulb pump (as in an outboard tank line) between the Racor and the mechanical fuel pump.Any experience with either?-- Finally, while dealing with accesss to the fuel tank, I discovered the quarter berth bunk appears to have been glassed in along the hull side. I was going to open up to search for a tank access port, but backed off.Does anyone know if this berth base which covers the tank is glassed in, or should it come loose with a tug or two? I could consider cutting a hatch through the wood to get to the tank. Ideas?ThanksSandersSV Good News
