Bleach and Gelcoat
Jason
I've recently purchased a 1981 Hunter 27. Overall it is in good shape except for some mildew and black staining on gelcoat. A fellow boat owner has been using bleach solution like tilex on the grime. Is there any problem doing this either short term or long term?
Dec 2, 1999
15,184
Bleach and soap works well.
Jason: Bleach and soapy water works well to remove the mold/mildew from the decks. The one advantage of using bleach is that it kills the spores. You can also use a power washer if that does not get the stuff off. Be sure to be careful if you use a power washer around ports, deck hardware or any wood. It can remove the softwood and raise the grain. On the hardware and ports it can cause leaking.
Hunter 33_77-83 Lake Lanier GA
You need to give it a couple of days...
to work. I wash my boat with the mixture and find its cleaner 2-3 days later when the bleach has had time to really work. Believe me,... it works.
Terry
Hi Jason, the guy that surveyed our boat...
advised me to use soft scrub, the household cleaner, to remove stains, mildew and grime on most all parts of the boat. When we purchased our boat last year it had quit a bit of mildew on the padded liners as well as grime inside and out. The stuff works great and no return mildew one year later. Terry
