Black water line scale
7
Grampian G-26 None yet
You won't
I don't think you will find any chemical that will do it without some sort of scrubbing. The only success I had was by continually circulating a bleach and water mix through the system. But by doing that you're only making it look better it's not really removing the build-up. I suspect that it's just mineral or iron deposits and really is doing no harm unless it's building up so much that it's restricting flow that is. If we could see into our house plumbing I bet we'd be disgusted. Maybe you could replace your plumbing with black plastic pipe :)
RichH
Feb 14, 2005
4,773
Probably fungal filaments ....
Mildew, and other fungals easily 'permeate' polymers by growing their mycelium filaments INTO the soft plastic. So, if the 'scale' isnt mineral deposits what you see is the old dead fungus filaments IN and under the 'skin' surface of the plastic.
Ross
Jun 15, 2004
14,693
Bleach will help with the appearance and the taste
Each spring when I recommission I dump a gallon of bleach into the system and pump it through to the faucets and let is sit for an hour and then rince like crazy until the water at the faucets is free of bleach smell.
Do a forum archive search on the word
"recommissioning" and you'll find Peggie's posts on just this subject in search find #9.
Dec 2, 1997
9,011
- - LIttle Rock
I'll make it easy for him and post it again
Before beginning, turn off hot water heater at the breaker; do not turn it on again until the entire recommissioning is complete. Icemakers should be left running to allow cleaning out of the water feed line; however the first two buckets of ice—the bucket generated during recommissioning and the first bucketful afterward--should be discarded. 1. Prepare a chlorine solution using one gallon of water and 1/2 cup (4 oz) Clorox or Purex household bleach (5% sodium Hypochlorite solution ). With tank empty, pour chlorine solution into tank. Use one gallon of solution for each 5 gallons of tank capacity. (There's a MUCH easier way: use a quart of bleach to 50 gallons of water...or 1 pint of bleach to 25 gallons water). 2. Complete filling of tank with fresh water. Open each faucet and drain cock until air has been released and the entire system is filled. Do not turn off the pump; it must remain on to keep the system pressurized and the solution in the lines 3. Allow to stand for at least three hours, but no longer than 24 hours. 4 Drain through every faucet on the boat (and if you haven't done this in a while, it's a good idea to remove any diffusion screens from the faucets, because what's likely to come out will clog them). Fill the tank again with fresh water only, drain again through every faucet on the boat. 5. To remove excess chlorine taste or odor which might remain, prepare a solution of one quart white vinegar to five gallons water and allow this solution to agitate in tank for several days by vehicle motion. 6. Drain tank again through every faucet, and flush the lines again by fill the tank 1/4-1/2 full and again flushing with potable water. This should be annually as part of spring recommissioning. It also gets rid of any antifreeze taste/smell
