Watch your
watch your lower unit oil. On that motor, there are only two places any oil can come from. If your lower unit isn't losing oil or getting water in it, then it is unburned engine oil. Not a problem. But you might check your fuel mixture, or change oil brands to help it some. If your losing lower unit oil, or have water intrusion into the lower unit, you have a seal leaking. There is a seal on the prop shaft, and one on top of the gear housing under the water pump. Some of the smaller outboards do not have a seal on top of the water pump and some do, but this will not let oil leak out. Only the one on the prop shaft and on top where the drive shaft goes in will let oil leak out. Pull the drain plug on the bottom, under the gear housing, just enough to get a couple of drops out. Make sure the engine has sat at least a couple of hours. If you have any water in the lower unit it will be what comes out first. You only need to let out a few drops to check. If it has water in it, the oil is gone, or going, and you need to replace the seals. If you have to do this, don't waste time and money replacing one.
