I installed a 2GM Yanmar engine in the spring. Before doing I removed any oil that was in the engine and put in fresh oil along with filters, etc. Throughout the season I would periodically check the oil level and the dip stick would always come out with pitch black oil.
Yesterday I was getting the boat ready for the winter haul out and changed the oil by pumping it out and I then added fresh oil (amber color 15-40 diesel oil) and then when I pulled the dip stick the oil was black and I had about a cup of black oil flow out of the dip stick hole.
My first question is...should the oil be black? And my second question is, am I somehow not getting all the oil out of the oil pan and then putting too much in causing it to flow out of the dip stick?
I am a bit concerned as I don't think that the oil should continue to be black. The engine seems to run fine, but I am not sure of how much oil I actually have in the engine as I can never get a read on the dip stick as the oil level aways seems to be high.
Is it possible that I am not pumping all the oil out? Any thoughts on what might be happening?
