black gunk on the back of your boat
7
Hunter 30_74-83 beaufort
what is the best way to get rid of the black gunk on the back of your boat after youve been running your engine. thanks
Jun 3, 2004
347
Hunter 30_74-83 Lake Lanier, GA
Richard,
Black gunk is a sign the engine is being run overloaded. I'm assumeing you also get smoke when running? What engine do you have? What rpm can you acheive at full throtle in foreward? When was the last time the bottom was cleaned? Back to the original question, try soft scrub or acetone. Pat McCartin Inland Marine Diesel Buford, GA
E
Eric C Lindstrom
Collinite cleaner ...
I guarantee Collinite works on this exact problem! Great product (I think you can get it through Boat US or West).
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
A GOOD tune up
...or maybe a problem with the prop. In either case you should not be seeing black soot coming from a healthy engine and prop.
K
Kevin O'Neal
Boat Soat gets the soot out...
I use simple 'Boat Soap' and the black soot washes right off. Never a problem. My engine is a 1 cylander diesel Yanmar. Not much tuning you can do to that puppy. It's my understanding that much of the "soot" is from unburned diesel at time of engine shut off. But, even after cranking the rpm (in neutral) right before shut down (as reccomended in the owners manual), I still get a bit of smoke, a small black skid on the water, and after several outings a black film on the bottom of the transom. I haven't dared to run her over 3000rpm, and usually settle between 2200 and 2500rpm. Bottom is race ready. If anyone has any ideas on how to eliminate this in the single-hammer Yanmars, I'm all ears! Kevin in VT
