bimini top for Capri 22
43
- - kamloops bc canada
Does anyone have any pictures or specs for a bimini top for a Catalina capri 22'. does is the boom height sufficent enough for this? Thanks Bill
Jan 25, 2007
47
- - Great sacandaga
bimini tops
Bill, I'm not sure about the capri's,(I have a C-22), but I do know that a good source of bimini's would be at overton's. The prices seem good, you can order the bimini's that will fit your boat. It depends where you want to mount your rails. They offer different heights as well. So the boom height will be no problem. You might want to consider spending a little more for the stainless steel frame though. If you sail with it up, and it's a good blow, you will want the strength that the stainless steel will give you. I hope this helps a little. Jay
