bimini 240 plus minus
I have a 6' binimi and its pluses are more than its minuses. I have had it up in gust 20 plus and it has not even looked like it was under load. On a hot sun day and low wind day it is a must, or even hot and windy. I have it in every possible position, and have bought the plastic screws that you can screw and unscrew by hand (connecting the bottom of the posts to the boat mounting brackets). Some days I have it stowed in the upright position and lean against it while standing and sailing (great back rest) , great thing is that you can tack and still have room as you stand back as the boom zooms by your nose. If you have and use the rail seats, my bar stood of choice then I usually undo the four screw and slide the bimini under the seats and then I just do up the front screws to secure it. It is worth the few minutes of effort for the un interupted view. Sorry no photo electronically deficient. I followed the instructions and the measurements and it worked out, go figure.
