K
Kevin Bladsacker
I have an aftermarket bimini (only seen folded) on a recently purchased used boat. It seems that part of the bimini frame should be fore of the backstay and one rod is aft when it up properly. I have seen similar biminis on other boats. When the inspection was done, the yard rigger had the backstay off. When he reattached it the bimini frame is all on the wrong side of the backstay. I loosened the backstay turnbuckles as much as i could but it never seemed to be enough slack to unhook the cable at the eye on deck. What am I missing? When the rigger attached the backstay it seemed like he just leaned over and hooked it then spun the turnbuck easily until it was taut. Now when I try to repeat that in reverse it seems like its full of tension.
