A
Andy
We are resewing our aft bimini. PO had front edge attached with lift the dot fasteners. I don't really like them because they are hard to attach and catch loose traveler lines when the bimini is stowed.Newer Hunters use a luft track that appears to be stainless steel. An aluminium track and plastic track are available through canvas suppliers. Plastic will dregrade and doesn't look as nice (but doesn't get permenantly bent). Aluminium would look better but is a dissimilar metal that would cause rust. I don't even know if a stainless steel is available as a replacement.So, what would you or have you done?
