Bilge
Dec 18, 2016
41
Hunter 306 ft lauderdale
I have a 2003 Hunter 360.
was looking at bilge over weekend as I was going to replace the pump as the float switch as it is in poor shape (pump and switch are separate).
I have what i believe is a raw water filter that comes from the thru hull seacock just forward of the engine that is heading to the port side under the deck. the filter has an arrow also pointing to port possibly heading to galley sink. is there an option for raw water at the sink??? i originally was thinking this was the pick up for the head but i believe that thru hole is on the port side just aft of engine.
There is another line in the bilge which i believe is the drain for the shower that dumps into bilge.
There is another line with a strainer on it which i think may be from the Ice box.
There also is an air con unit on the boat with a pump (red in color) forward of the bilge. is there a thru hull for that pick up and if so do you know where.
Any opinions please.
Gavmc
Oct 18, 2014
8
Beneteau Oceanis 37 Sunrise Cove
Ron, I would expect lines with strainer/filter are feeding pumps, electric pumps. One strainer is probably your AC unit, not sure the other. You should also have a manual bilge pump, that would have a separate hose into the bilge for it. Trace the line from your AC pump and it should take you to the through hull that feeds it.
Good luck!
