My maiden voyage...
Jim et al,Jim, sorry to hear of your problems.My maiden voyage went something like this: Friday (26th) rigging the boat, no boom vang?? Launch boat and head out, rudder won't go all the way down and the "downhaul line" is completely USELESS. To summarize, there is a block/sheeve/pulley, whatever you care to call it, in the rudderpost that, I assume, is to give some mechanical advantage when lowering the rudder. Well, where the block is located, is between the two bolts through the rudder post (one for the wheel steering and the lower one at the base (top of the white plastic piece), so that you CANNOT use the downhaul cause the block hits the bolt as you pull it up. I had the same problem with my former 240. On that boat, as well as on this 260, I removed the pulley via the bottom of the rudder post and re-tied the line for the rudder downhaul. I may try to reinstall the block above the steering bolt but that may require a longer piece of line for the rudder downhaul, and who knows, there still may not be enough room for the block to operate between the steering bolt and the bolt at the top of the post. Secondly, another bolt on the rudder bracket, the one whose function appears to be to act as a pivot point for the rudder downhaul line (has a sleeve inside the bracket) was also preventing the rudder from going down completely, I removed that bolt as well. Now the rudder assumes the proper position.So we're sailin...I happen to look in the forward port settee locker and find some water sloshing in there that appears to be comming around between the liner and the hull on the forward/port side, much smaller amount on the starboard side. What the.... I'm thinking, that judging from the apparent location/direction of the water, that the dealer may have punctured the balast tank when installing batteries in the forward compartment aft of the water tank. I check the balast tank fill area under the step and there is a pretty good leak going there where the plug is installed. I pull the plug out without even flipping the lever up, then I REALLY had a leak. I tightened the plug to make it much fatter and put it back in the hole. QUESTION: is that balast tank supposed to be that full? Doesn't that plate on the bottom of the hull seal shut? In our 240 I seem to remember the water level being about two inches below that hole and never being a problem.I sponged up the water in the settee and will be keeping a close eye on the area and am keeping my fingers crossed that the balast tank vent leak was the source.After using the head, happened to notice water under the vanity, that seems to be a leak in the seacock plumbing near where the hose connects. I will be disassembling that to reassemble using teflon tape, hopefully it is not stripped. I went through most of the boat and took an average of two to three turns on every hose clamp. I'm praying that the holding tank input hose clamps are OK, seems impossible to get to, even with the bulkhead out, without removing the tank.Oh yeah, when checking the sink pumps in the driveway, everything seemed OK. When my wife tries to use the galley pump it won't work properly. Remembering a previous post on this WEB site regarding a similar problem, I took a piece of surgical tubing and put it over the faucet in the head and clamped on a hemostat (sp?) to seal it off, then at least the galley pump worked OK. I will be adding some real check valves soon.Good sailing,Tom M.
