Bilge water and starboard Limber holes
Brian
I have a problem of water collecting in the locker under the starboard setee. Water will migrate during starboard heel from other bilge areas thru limber holes fore and aft that are at a higher set on even keel. In short water will enter on heel and not drain when even. The port locker does not have this problem as the limber hole is at its lowest point. Has anybody experienced and solved this. Brian
