Tom Payne
Fellow Wind Seekers,Quick description then question! My V-32 has a bilge under the engine. There are two holes about 8 inches up that allow wires and hoses into the engine compartment. This is were my engine bilge drains when the water level gets to high or if I am on a sevre heel. The water then escapes into a passage way that leads to the main bilge and bilge pump. I could drill a hole so that the engine bilge is always dry allowing the water into the passage ways that lead to my main bilge. I think I once heard Hunter designed the engine bilge to hold water so we could see what was leaking from our engine. As I write this article a question does enter my mind, Where is the water coming from??? But that will answered another day!!! Well what do you guys think??? Drill to drain or leave it alone????Thanks Guys, Your help is always very appreciated!!!Daddy's Dream
