Hello allI have a Rule 2000 bilge pump connected to a Rule 35 float switch. Problem is that the switch does not turn on until the water is higher than I would like it. Is there any adjustments that can be made, or are there any better switches that people use?I have a Pearson P36-2 that has a shallow bilge. Hate having that much water in there. When I am sailing it is dry as I amnually drain it, however it is when I am not on the boat and rain water runs down the mast, gets into the bilge, then the heat can make a mess in that nice, dark, wet bilge.Thanks as alwaysGreg
