I have had a couple of interesting moments with my electric bilge pump siphoning water back into the boat after pumping out the bilge. Here's the scenario...After motoring a couple of hours on a little to no wind day, my wife went below to make some lunch and shouted to inform me of water pouring in. Pretty alarming as we were 15 miles offshore. I throttled back to a slow idle and the water stopped. After scouring the boat for a leak, I settled on a siphon as the answer for the water, and figured that it had to be either the manual or electric bilge pump since the through hulls are underwater as the boat squats while under power. After turning the boat around and aborting our trip (since I could not fully convince myself or my wife of my theory), I tried to confirm the siphon by throttling back up but could not get it to come back.Back at the marina, I checked over the entire boat, hoses, through hulls and found no evidence of a leak. A couple of weeks went by and this past weekend we had a crew of people aboard and all of their gear and I noticed that the boat was squatting again, this time not under power but because of the weight of the extra crew and poorly distributed gear. The siphon came back and I confirmed that it was the electric bilge pump by unhooking it from the plastic strainer and raising it up to see a stream of water pouring into the bilge. So now with my suspicion confirmed, I want to get the intermittant siphoning to stop so what I'm thinking I need is to place a vented loop into the high spot in the hose. As it is now, there is a loop well above waterline but somehow this is not enough to keep the siphon from starting. I thought of placing a check valve in the line but know it is not recommended even though plenty of people do it anyway. Anyone else have a similar experience? Am I on the right track?
