bilge question
1
- - Echo Bay, Lake Mead, Nevada
We have a 1982 Catalina 25,swing keel. It appears that the water drained from the sink in the galley and head drain into the bilge area. there are 4 compartments visible when we remove the two wooden pieces in the sole. the bilge pump itself sounds like it is located on the starboard side of the hump which is probably where the keel fits under the hull. the water does not drain into the area where the bilge pump is located from the other areas. we have purchased a hand pump to get the other areas dried out. is there something we can do to take care of this little annoyance?
C25-C250 Association
The water from the sinks should go to thru hulls and out of the boat not into the bilge. Go to the C25 association website and check in with them, they're experts on your boat. www.catalina25-250.org Stu
