Bilge Pump
Bob
Anyone have any recomendations on Bilge pumps. I am not takig any chances, I am replacing the clunker that there, looks like it has seen better days, and while I have everything open, it just makes sense to change it and the hose.
Bob
L
lugeman
reallynot taking chances
BOB, Replaced my pump with a Rulle 1100 ( 1100 gal an hour) Pumps out the bilge in about 5 minutes when full. also installed a manual pump just behind the starboard cockpit locker with the handle through the the deck with the pump below. Good set up if power fails. Pray for wind Lugeman
L
lugeman
Jun 5, 2004
242
None None Greater Cincinnati
Go with more than 1.
Right now I have 2, a Rule 2000 and a rule 800 that are always ready to go (float switch activated.) I also have a small one that I want to put in the lowest, lowest part of the bilge with a small, small line (to minimize back flow when the pump stops) just to keep the bilge extra dry. This involves cleaning the bilge and I haven't done it. I also have a 2nd Rule 2000 I want to install higher up in the bilge on a manual switch. Haven't gotten to it. An alarm would be good too. The bigger pumps/more pumps you have, the longer you can work to solve any "problem" you might someday have.
Gene G
Jun 11, 2004
38
- - Austin, Tx
2 pumps - excellent advice
I have a second one used as a shower pump. I have it, along with a float switch, mounted on a metal plate. When we leave the boat for extended periods of time, I take the plate from the shower sump and put it into the bilge, giving a backup pump. Both pumps are Rule 2000. It's a bit of an over kill for a shower pump, but not for a bilge pump. If you are away from home I'd suggest taking an extra one or two as spares. You never know when you might need one. I was surprised how many people we ran into in The Bahamas who had no spares. Like this guy: http://www.geocities.com/rainbow_chaser.geo/tomcat.html
john
any boat over 22 feet, I always use two pumps
both on auto floats. I check them often. One day I arrived to my sailboat on a mooring after a couple of weeks to find about 1/4" of water in the salon. A piece of candy wrapper got into the bilge and jammed the pump.
