The Sahara S500 bilge pump in my boat died last week. I cleaned it a month ago as the float had been sticking in the down position. I used the check knob on the back and it worked just fine. Apparently, some time last week, it got stuck in the up (run) position. The pump ran continuously for an unknown number of hours and somewhere along the line it gave up. With power applied it tries to turn but cannot lift water.
I've looked about the web for a replacement. This is complicated by the very tight space in the 310 bilge, both side to side and fore/aft. Many pumps just won't fit. Based on the reviews, all the mechanical float switches, Attwood, Rule, Shurflo fail on a regular basis and the passive switches gum up from silt and other bilge debris and also quit. It would appear the industry has not found a solution to the banning of mercury switches.
In the end, I've ordered another Sahara S500 as I can use the screen mounting base from the previous one and just plug int he top of the new one. The Sahara is supposed to be mounted fore/aft, but the placement of the keel bolts wont permit it.
Another point. It seems I have a check valve in the discharge line. Should I remove it?
