Bilge Pump
Jun 19, 2011
8
Catalina 270LE NashvilleShores
My '93 bilge pump gave out but the new pump will not remove water in the bilge. It seems to be working when I use the manual setting. Any suggestions?
A bit more information would be helpful.
Can you be a bit more specific about what happens? Like, what happens when you lift the float on the float switch? Does the pump pump and the water run back? Please describe what happens in some detail so we can give you good advice.
Likes: ggrizzard
