In reviewing the electrical diagrams for my 1996 Hunter 280, I made a surprising discovery....it appears that the bilge pump ONLY draws power from battery #1 on the Perko switch. I assumed that the bilge would be wired to the common terminal on the switch so it would draw power from both batteries.
Is this the normal set up?
I have 2 batteries....a starter battery and a deep cycle house battery....I did not think it mattered which battery was on which switch...but now I am not so sure....
Should the house battery or the starter battery be wired to the #1 switch position (which also powers the bilge pump)?
Also, my DC panel has a breaker marked "LP GAS". I don't have LP gas...but does anyone know if Hunter would have run wires and where they would terminate? I am looking for an easy way to add a 12 volt power plug in the cabin, and it would seem like an easy solution if the wires from this breaker are already run to the port or starboard side of the cabin.
Greg
Greg
