Bilge Pump Wiring Protocol
181
Hunter 260 Portland, OR
Is there a correct way for bilge pump wiring? My fused pump runs through a master DC House Bank battery breaker switch. When turned on, the switch energizes the DC electrical panel and a hard-wired CO detector. Should the pump be hard-wired (with its inline fuse) directly to the battery? Thanks.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Hard wire it
You got it right. You want the pump wired to the battery. Make sure you use an inline fuse to protect the circuit. When you wire it directly to the battery you avoid the risk of not having a switch turned on which would prevent the pump from running when it needs to.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Hard Wire
Hard wire it direct to the battery bank. This way you can kill everything else in the boat with the battery switch. Eliminates any chance of cutting the pump off, or leaving something else on to run the battery down. Be sure to fuse it.
Dec 2, 1999
15,184
You need an automatic & manual connection
Bob: You need to have a float switch wired to the circuit & a manual switch to pump the bilge too. It should have some instruction with the pump/float switch.
May 6, 2004
916
Hunter 37C Seattle
Hard wire but keep panel switch
With the panel switch bypassing the float/switch. So when you turn on panel switch pump turns on and stays on until you flip the switch and with panel switch off, when you lift the float the pump comes on. What Steve said ( jeese he's a fast typist), so nevermind.
