Bilge pump thru-hull
Beneteau 42cc Oriental NC
I was appalled to find that on our 2002 Beneteau Oceanis CC Clipper that the bilge pump thru-hulls are below the water line. Of course, this arrangement is guaranteed to sink the boat in the event of a failure. BTW, this is a French-built model.
Really curious if any other Beneteaus have this incredible design flaw.
Boyd Gatlin
s/v Ida Lou
Oriental, NC
Gunni
Mar 16, 2010
5,937
Well Boyd, you are really going to be appalled to find out that your raw water intake thru- haul, head thru-hulls, ac thru-hullls, and transponder/speed thru-hulls are all below the water line. Make sure your bilge pump thru hull has an anti-siphon loop...inspect your thru hulls regularly, and if you are nervous about these holes in your hull, close them when leaving her.
