I need to replace my bilge pump through-hull fitting on my 1982 H30, but the access is hidden under the port settee. I'm 6'4" and 240 and way too big to cram myself into the area, and even the admiral (5'3", 105 lbs) is too large to get in there. Has anyone had this situation, and if so, how did you solve it.
I have considered pushing a new hose in from the exterior, and then joining it to the existing hose from the bilge pump, but it is not a straight shot, and I'm not sure I would be able to do that.
I do have a slow drip from the shaft packing, so several times a day, the bilge pump does its thing, and I'm afraid of getting water either pumped back into the boat, or of getting water pumped into the fiberglass hull and causing delamination.
Does anyone have any information that may help me?
