Mickey Goodman
When I went through the spring commissioning I found that my bilge pump would turn on but wouldn't pump the water out of the bilge. I spoke to a marine electrician who told me that the Rule 1500 pumps run based on the amount of current applied to it and that over time the motor will run but be weakened and not pump properly.I figure with the boat being a 1988 that after 13 years a new pump was probably in order. So after buying a new 1500 Rule from BoatUS and installing it I found the same problem. The pump would work intermittently sometimes pumping and sometimes not even though the motor was running.Could this be a hole in the hose between the pump and the through-hull? This is to important a piece of equipment that needs to work "all the time when needed" rather than intermittently.Any help/suggestions would be greatly appreciated.
