tom
The shower drains into a tank instead of the bilge. Anyway the tank was pumped out with a diaphram pump controlled by a switch. The pump and switch have failed.My proposed solution.1.Cut a hole in the tank cover.2. Put in an automatic bilge pump.My reasoning is that this arrangement will keep stuff out of the bilge and will eliminate the need to turn on a switch. An added benefit is that if the primary bilge pump failed the pump in the tank could help keep the boat afloat once the water was deep enough to flow into the tank.Any reasons that this wouldn't work??thanks Tom
