More on Weep Hole Water
JoellePeter had some excellent points regarding the chain plates. Make sure you re-bed every couple of years. Anyway, There is hidden water in the bilge just aft of the sole inset (Where the wood sole panels sit. I believe this water makes its way into the center pans (Where the keel bolts are). If that's what your asking about, you will find that even when you clean up the water from the bilge pans, you will still see water seep back down into the pans. I found that if you clean up the water and you wait a few minutes, clean again for 3 or so times, you won't damage the bilge with frozen water. In my earlier years with the boat, I had some of that residual water and did not pose a problem. As for the Hull to deck joint, it's the attachment point of the deck to hull hidden by the rubber bumper that goes around the boat. The right way to deal with this is to take off the entire bumper, seal the joint and replace the bumper. My alternate suggestion was to just take a 'boatlife' type of caulking and just seal the crack between the bumper and the deck. This is a big bang for the 20 minutes to do the job.Let me know if that helps,/ChuckS/V Windsongs, '85 H23
