Dan
Does anyone with a Hunter 25.5 have a bilge pump mounted in the recessed area at the keel? If so where do you have the discharge hose running to? I want to mount my bilge pump in this recess since it is obviously the lowest point in the boat. I am thinking about trying to run the discharge to a thru-hull near the outlet for the vanity sink in the head, as high as possible above the waterline. To do this I will have to drill a hole in the inner liner under the sink to get the hose down into the bilge area. Has anyone done this or know of any problems that I might run into when I do this?Any help or tips would be appreciated.Thanks,Dan
