Bilge pump frequency..
May 30, 2006
1,075
How often do you have to run your bilge
pump?
Mine is manual and seems like I have to
run it every week now or it will cover my
batteries (my pump is on top of fuel tank so
we're only talking 6 in. ). But it seems like
I rarely had to run it before.
Or is that my imagination?
Sent from my iPhone
Oct 31, 2019
562
I can't give an answer on how often my bilge pump runs. I have an automatic switch.
But you can take a good look at the stuffing box- is there any water coming in? Put a piece of paper under the place where the shaft comes in. Other places- more worrysome, are through hull fittings.
If it rains a lot, water find its way into a boat.
Good luck,
Wilhelm, V-257
Jul 10, 2009
125
I don't have any water coming in. Perhaps you have a bit of a leak
through a thru hull. Colin...
Groundhog wrote:
Oct 31, 2019
230
I was taught to adjust stuffing box to allow at least a dozen drips per
minute when operating - for lubrication. When it is adjusted as such,
it always drips, albeit less frequently, when engine is off. Hence,
even in dry weather, water accumulates in the bilge between trips. Trev
(V 2915)
________________________________
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On
Behalf Of Colin
Sent: July 18, 2008 9:10 AM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Bilge pump frequency..
Groundhog wrote:
Oct 31, 2019
562
Hi;
you must have a different stuffing box. Mine is drippless, no water comes in. If it does, I just change the two seals and a bush, and for the next 4 to 5 years (depending how much I use the engine), no water comes through the stuffing box.
Wilhelm, V-257
Oct 2, 2005
465
Like Wilhelm we have a Dripless Shaft Seal, which is a very nice
system. shaftseal.com When there is water in the bilge it is always
from another source, otherwise the bilge would be dusty.
Craig V1519
