Does anyone else have a problem with their bilge pump gettig air locked? Went down to the boat in advance of hurricane Irene and found my bilge pump running but not pumping. There was only an inch or so of water in the bilge, just enough to activate the float switch. I even took the discharge hose off and it would still not pump except for a week stream. I banged the pump few times, lifted it in and out of the water and it finally caught and pumped the bilge dry. The pump was not fouled, it just would not pump and I assume it was air locked.
