jim
I need some help. I have a joining bilge areas about ten inches apart. The forward floor underside sweats so bad that I had to take it home, dry it out and glue the laminate back then coat the whole area with epoxy. The aft flooring section is dry as a bone. Both areas have the same water level and are connected. Why is the forward section sweating? Any ideas?
