K
ken
While sailing my catalina 320 this weekend water came up through the floor boards in the cabin. After toggling the bilge on the fuse panel to "on" and manually bailing the water, I averted a crisis. There are "2" bilge swithces on my fuse panel. The 1st is a toggle "on/off"... where the batteries need be "on" (this is the one i engaged.) The other switch says "manual/automatic"- this one i leave on "auto" with the batteries turned off when i leave the boat. The float switch in the bilge, worked with "on/OFF" toggle switched "on"...however did not work with the toggle switch in the "off" position.. are there two separate bilges..?? i dont think there are but..cant figure out how the water got so high unchecked. The "manual/auto bilge" should have kicked in. Any recommendations/advice on this subject? This was the first of such occurrences.
