The bilge pump topic
If no one minds, I wold like to continue this discussion along more general terms. I am installing bilge pumping system (or "de-watering" system"). How does one determine how much pumping capacity to install? What about check valves? Here's what I'm doing:I have a C-36 that had only the manual pump. I measured 7" of vertical space available, so I bought two of the biggest commonly available pumps that would fit - Rule 2000's (Model 10); plus 2 Rule-a-matic Plus shrouded (enclosed) mercury switches. These pumps will be installed in the bilge at either end of the center bilge access floor board, wired to seperate "ON-OFF-AUTO" switches on the panel, and piped seperately to through-hulls in the transom with a loop of hose as high up inside the hull as practically possible. This will be the emergency pumping system, and therefore won't have check valvels which could impair pumping. A third small (360 GPH) pump with a check valve will be used to dry the bilge. This pump's switch will turn on first. The big guys will not come on unless there's a real problem. Rationale:1. The biggest pump that fits isn't really that much money - I paid about $65. each at West Marine. The 1500's were the same exact size, and about $12. less, and much less power (4.8 Amps versus 8.4 Amps). 2. Two pumps is for "dual redundancy" - if one simply doesn't work, the other is available. I may even route the exhaust hoses along different paths, so that if one is damaged, likely the other won't be.Now, it was explained to me by a colleague that the truth of this is that if you punch a big hole in the boat, no on-board pump will save the boat, you have to plug the hole. However, if you break a through-hull, will a pump save the boat? How many gallons per hour will flow in through a snapped off through hull a couple of feet below the water line? Comments?jvIncidentally, about pump ratings: On the housing of the model 10 is printed: "Pumps 2000 GPH; 12 Volts; 8.4 Amps." However, in the enclosed printe instructions is a table that indicates the capacity for a head of 0', 3.35' and 6.7', for both 12.0V and 13.6V - and the highest capacity is 2000 GPH at 0' and 13.6V. It never pumps 2000 at 12V.
