I keep hearing warnings about not using a check valve in the bilge. I used one and it has worked fine. They are extremely simple and reliable. The alternative was to have the backwash continuously cycling the automatic pump and burn it out. Why should the weight of the water stop a check valve from working if the pump has the capability of pushing that water out any other time? I can see a jam of the valve occuring over time, but that is like anything else that should be regularly tested to ensure it is working. Your pump can fail too and a check valve is a lot simpler than a pump and doesn't need electricity. Comments? Lessons Learned?
