James
Need some help on automatic bilge and switch . My automatic bilge is a Rule 1100 with a float switch. Both are schewed into area where the Keel bolts attach inbetween the manual bilge. The float switch and the bilge operate automaticly. However, when the automatic bilge shuts off there is a back flow of water into the bilge and the float switch is activated again. So ! it never stops running. I purchased this Hunter ,340, 1998 used. So I dont know what the original set up was. Possibly the previous owner changed the set up. Ant ideas?
