Bill Ebling
It was recommended by our surveyor that I should install a bilge alarm when we bought our 1985 hunter 31 two years ago. Never installed but put on the “nice to have” list. This weekend I was doing routine inspections and found the bilge pumps float switch had failed. Fortunately I have a dry bilge, but if something did break loose I could have been SOL. I am now moving the bilge alarm from the “nice to have” list to “should have” or “must have” list. I’ve seen bilge alarms in the catalogues that come with their own buzzer. The boat is left unattended on shore power during the week. For the alarm to have value if something has gone awry it would have to alert either a dock mate or marina personnel. To be audible from the closed up boat I am assuming that the buzzer must be mounted outside in the cockpit. Since I don’t want to add more holes to cockpit I was hoping that I could use the engine buzzer that’s already in the cockpitQuestion. Has anybody mounted a secondary float switch higher up in the bilge and wired this to sound off a “high water” alarm using the Yanmar instrument panel buzzer? If so how can this be done and keep the other alarms working properly? My boat has the Large B type pannel. From the Yanmar wiring diagrams it appears that the buzzer's hot side is routed through the key switch. The engine alarm switches (low oil pres, Hot water temp) close the ground to sound off the buzzer. Without the key switch turned on, the buzzer can't be activated.
