I've fairly certain that I will be replacing the original 3/8 inch
thru-hull, used for engine cooling, with a 3/4 inch one, assuming
there is space at the current spot for the bigger hole and valve.
Having a hole already there complicates the cutting chore. The hole
cutting instruments that I have seen use a drill bit in the center to
keep the cutting tool centered. The best idea I have come up with is
to glue a plywood disk across the current hole that is slightly
smaller than the hole I am cutting. This would give the cutting tool
a surface to use for centering. Any other ideas/comments?
Thanks,
Chris
V-2933
