Re: Primaries
While we have an '88 H-35, the situation with the winches is the same as on your boat, as in undersized. The OEM primaries winches were 24's which I removed and moved aft as secondaries. In their place were installed Lewmar 43s which, while expensive even on sale, were one of the best investments. Like the song, you don't know what you've missed until it's gone. When one does a price comparison between 24s and 43s it is readily apparent why the manufacturer chose the 24s - they're much cheaper. I think the newer 35.5s have 43s as standard.In comparison to the 24s, the 43s are like power steering or power brakes. If you steer and let your wife run the jib sheets she will really appreciate the larger winches. The primaries get a lot of use so the other advantage is that parts, if they're ever needed, are readily available for the Lewmars.The recommended size of winch can be found in the winch manufacturers catalog but for fractionally rigged boats one will will need to make some adjustments if the tables are for masthead rigs. The 100 percent sail area will be the determining factor. The winch mounting locations have aluminum backing plates which are built-in to the fiberglass deck. Another reason for the change is the larger primaries are very useful for hoisting a person up the mast, a potential safety factor. I had a spinnaker hourglass wrap once and the winds climbed to over 20 knots and my wife had to hoist me up - the larger winches were really nice.
