Sail Trim
God put the sail trim controls for the main and jib on a boat for a very good reason - there is a particular setting for each point of sail and wind condition and you have to adjust them accordingly or your controls will be like the broken clock which is right twice a day. Joe (Mission Bay) hit it right away - I figured it would be him or Alan or Stu or one of many on this list that know their sail trim onions. As Joe indicated, the sails have to be tight in very light winds because the wind does not have the force to get around the sail and the sail stalls. On any given light air day you'll see mates with big bellies in their sails "trying to catch the wind". They do catch it but the wind has to flow over the sail for the boat to move forward and it can't with a big belly in the sails.Here, in very simple, basic terms is what your sails should look like as you progrss through the range of wind speed. In very light air you start with a flat sail. As the wind pipes up you gradually belly out the sail say up to 12 knots. At that point you start working your way back to a flat sail. After that, your next step is to reef. Why do you want a flat sail before you reef? It is because a flat sail lacks power and your trying to control the boat. This may sound confusing and if it does just fire away with any questions and I'll do my best to give you an answer.So now to Ray B's question. "Loose" is a relative term. I don't know how loose loose really is. Very loose is probably looser than loose so I assume the outhaul, halyard, vang etc were slacked off. Ray B was in last place and going nowhere in light air because his boat was set up for a higher wind condition and when those conditions materialized he took off. It really is as simple as that.If a begginer or intermediate wants to get decent performance from his sails he or she has to understand draft depth, draft position, twist and angle of attack plus they have to the purpose of each sail trim control for the main and jib. At that point they are almost home from a sail trim standpoint. The MOST IMPORTANT last piece is knowing the correct sail trim control setting for each control on the main and jib for each point of sail and wind condition.Sounds like a lot of stuff to learn doesn't it? It is no different than learning to hit a baseball, tennis or golf ball. If you want to improve there is the price to pay. There are a couple of ways to learn this stuff - trial and error and you'll be old and gray before you finish. Take lessons and you'll be broke - hopefully you'll find an instructor who can explain sail trim in plain English (I couldn't). There is another way. Take a look at my book THE SAIL TRIM USERS GUIDE or my SAIL TRIM CHART.There is not one sail trim question that has EVER come up on this sail trim forum that a mate couldn't answer by referring to either of those products. Like, where do you think I get my answers!?! I don't make this stuff up as I go along. It's like riding a bike. Once you learn to ride that is about it - nuclear research it ain't.
